JDM Performance Posted January 12, 2006 Posted January 12, 2006 OK, newbie question. When the traction control is on, does the light on the dash light up, or is it off? Reason is, the light is off on my car, so I assume the TC is on.... But, I have already managed to wheelspin 3 times and get it very out of sorts on a roundabout... which would make me think the TC is off? Chris Quote
Guest prescience Posted January 12, 2006 Posted January 12, 2006 As you say when the light is OFF the traction control is ON - you can still wheelspin the car, no problem - particularly in winter conditions. Many people do drive with TC OFF (i.e. light ON) all the time - except perhaps the worst conditions. Quote
JDM Performance Posted January 12, 2006 Author Posted January 12, 2006 Ahhhhh penny | | | | v thanks chris Quote
350Znismo Posted January 12, 2006 Posted January 12, 2006 When the traction control is turned off, the indicator light comes on. Also the wheels will spin during (as the manual says) abrupt operation even with traction control on. Quote
Traktion Posted January 12, 2006 Posted January 12, 2006 The TC seems to kick in pretty late sometimes (which is good imo) and I only really notice it when I give it some extra welly around a corner and the TC cuts in after a little slide. I don't tend to welly it in 1st/2nd though or I don't get anywhere quick, just lots of spin! Quote
eddmac Posted January 12, 2006 Posted January 12, 2006 The traction control can actually cause you problems, if you are sliding sideways. If you are in this situation, sometimes the worst thing you can do is lift off! - which is exactly what the TC does. I had exactly this happen to me when exiting a roundabout, which had some kind of spill on the exit. The back end started coming out to the right and as i was correcting it, the TC kicked in, which made the back end immediately whip round to the left and nearly put me off the road. If I am driving "with spirit" I now turn the traction off. Quote
Traktion Posted January 12, 2006 Posted January 12, 2006 That has crossed my mind before Edd, but I figured it "knew best". Maybe it doesn't then! Quote
