rickya Posted July 4, 2006 Posted July 4, 2006 Ok so the ECU cancels out the effects of any mods as it is not at all adaptive, so Iv read. This is so for e.g. fitting ram air filters etc have no use-no power gains. So does that also mean that modifying the other end of the system i.e exhaust manifolds/cats/exhaust would aslo have no effect due to ECU lamda sensors in the exhaust? If this is so & they have no horsepower increases then why are they done - simply to change the driveability/cooling/ & weight saving? It would seem that maybe a simple grounding kit & larger plenum might therefore be the best two mods unless you are changing the ECU to an aftermarket programmable one. Any thoughts, am I talking rubbish!! Quote
Spill Posted July 4, 2006 Posted July 4, 2006 It would seem that maybe a simple grounding kit & larger plenum might therefore be the best two mods Quote
rickya Posted July 4, 2006 Author Posted July 4, 2006 Bloody hell Spill there arent any mods left to do to your motor! Cool Quote
rickya Posted July 4, 2006 Author Posted July 4, 2006 What a stroke of luck! Just about to look into buying a Groundink kit, looked carefully at engine & already have one, on the recently bought JDM. It looks like it is a Nismo one, it says in tiny writing what looks like "SILKO" but might be nismo? ps I am right in thinking the z had no grounding kit fitted at all from factory? Quote
Removed Posted July 4, 2006 Posted July 4, 2006 the answer to the title is.... noise. But that's about it mate mid range gains too I guess, but then you risk running too rich thanks again to the ECU, so really not much point. PS this thread belongs in "performance" Quote
rickya Posted July 4, 2006 Author Posted July 4, 2006 PS this thread belongs in "performance" Sorry, didnt realise! Quote
