Hi all,
My Bose sound system seems to have an intermittent fault where sometimes it’s nice & loud then under a bit of hard breaking or cornering its gets quieter. So using the balance option I found out that when listening to a cd the left hand side of the car sounds crackly & bassy! & the right side is perfect but when listening to the radio both sides are fine.
I assume all the speakers are amped & not connect direct to the head unit?
I assume this is a dodgey connection on the amp? Or some wires touching maybe?
Where is the amp located in the car?
Thanks,
Hi all,
Thanks,
I thought it gets queiter when slowing down? My clio did that was very annoying.
Yup had the same problem with mine, took out the unit and remove the white ribbon cable under the cassette player, te- fitted it and its fine now.
