Hi all
Looking for a set of 19's i have wanted to go 10-10.5 wide on the rear but have found a set i like but are only 9.5 on the rear. How much weaker will they look? or is it a case of whack a set of spacers on and will be fine? They have plenty of dish and are et38 so iwas thinking a 20mm spacer? also i assume a 10.5rear may give issues with dropping the car that i wouldn't get with a 9.5?
Thanks
et38 is a horrible offset but 20mm spacers should see you right. Will they fit the Z? TRD make toyota parts but im not sure if the Z has the same pcd as toyotas.
I've got my car lowered on a 10.5 rear with no issues but 3fiddyz has the same & has issues with it rubbing :)
They are currently on a skyline so should bolt on a z.
would like some a little wider but these are a good price and not seen much on the 2nd hand market.
et38 not ideal but nothing spacers cant fix could i go more than 20mm on standard ride height? as car isn't lowered yet
