Hi all
I am having an issue with my electric windows...
The passenger side window goes up/down ok but the drivers side doesnt work.
I have had the switches out and there is no loose wire in the harness connector and i have disconnected & reconnected the connection but still wont work. I have not managed to check the harness at the motor end, and im assuming its not a fuse issue as the passenger one work
Help :headhurt::headhurt:
WB
:welcome:
Try banging the door, I used to have to do it to get the motor to start working again. Sounds like a motor fault :)
:welcome:
yeah the motors get full of crud from the brushes
Thanks guys
I will give the door a slam tonight...see what happens, failing that I will do the reset option
Is it possible to clean the motor...or is it case of new one??
If so, Where from? How much? & are they easy to fit?
cheers
WB
:thumbs::thumbs::thumbs:
Having problems with my driver window too. Sticks when its fully down. Fine if you don't drop it down all the way. Auto-drop function works fine.
A couple of hard slams usually gets it working again, but its getting worse.
Just a thought on yours tho, Do the passenger & driver windows have different fuses?
