Hi guys will be fitting my JWT pop charger and ESR intake pipe tomorrow.
just wondering is there anything special i need to do or is it literally jus disconnect and fit the new one?
Do the sensors just plug straight back in new pipe and pop charger?
cheers :thumbs:
cheers :thumbs:
Just follow the instruction sheet which is with the heatshield and you should have no problems, if you get stuck just phone.
Theres a video in the guides section bud but basically its pretty straightforward. The most awkward bit is getting the screws into the heat shield. I had one of the 90 deg drives and that made it easy.
Just put the sensors back in and I was expectiong alsorts but just started it up and drove it.
+1 the screws for the heat shield took me longer than the rest of the job
