rear brakes
kashz
i havnt yet but im gna after work hopefully it will be the solution to the problem .... :teeth: is this normal tho does every 350z owner go through this squealin problem ..
Nope - i had my none-brembo rears replaced and there was no grinding at all.
Who was it on here recently that put one of their pads in the wrong way round??
I'd find out which side it is, and pop you wheel off to see if you can see anything wrong.
yep i did and still got the problem so going to put new pads and disk on rear so any tips
Bed them in properly or you'll 'glaze' them. I had my DS2500's fitted correctly, greased and follwed the bedding in procedure but they still squeeeeeled like buggery :blush:
