Runner130 Posted 12 hours ago Posted 12 hours ago Ok, so my saga with Nissan 370z continues. Car wont start, i checked and no 12v is coming down on the connector in the green wire. I google it around and found that if you bring + directly from battery to marron wire next to it it will send the signal to BCM that clutch is down so i did it and car started thanks god. Now I need to check what happened with green wire why no power in it. Quote
Runner130 Posted 12 hours ago Author Posted 12 hours ago Google again and it is saying that + is coming to the clutch sensor directly from IPDM box. But which one is it I can not figure it out? If I could check that there is no voltage after IPDM box that would be better for me as box is crazy expensive . So if anyone can read better the wiring please give me a hint where the wire goes through so i can check for the power I hope it was cut somewhere. Quote
Runner130 Posted 12 hours ago Author Posted 12 hours ago PS also if someone now where this connector goes I would be grateful. I don't see nothing around to connect it to Quote
Keith D Posted 8 hours ago Posted 8 hours ago (edited) Is this what you are looking for? Fuse 9, through the clutch interlock switch, pin 114 in BCM, but also t-off to the IPDM connector E6 pins 30/72 (green wire) should be 12v with clutch depressed 0v with clutch up Edited 8 hours ago by Keith D Quote
Runner130 Posted 6 hours ago Author Posted 6 hours ago 2 hours ago, Keith D said: Hi Keith. Thank you so much. I am the worst with diagrams looking here and in the element E6 there is no 30 /72.On my photo you think it is this green wire top right? Quote
Keith D Posted 4 hours ago Posted 4 hours ago (edited) Sorry its E5 and E7 nor E6, and meant 72 not 70 Edited 4 hours ago by Keith D Quote
