Clutch connector don't have 12v coming through the green wire which goes to the clutch sensor. Where to check?
Ok, so my saga with Nissan 370z continues.
Car wont start, i checked and no 12v is coming down on the connector in the green wire. I google it around and found that if you bring + directly from battery to marron wire next to it it will send the signal to BCM that clutch is down so i did it and car started thanks god.
Now I need to check what happened with green wire why no power in it.
Google again and it is saying that + is coming to the clutch sensor directly from IPDM box. But which one is it I can not figure it out? If I could check that there is no voltage after IPDM box that would be better for me as box is crazy expensive
. So if anyone can read better the wiring please give me a hint where the wire goes through so i can check for the power I hope it was cut somewhere.
Posted (edited)
Is this what you are looking for?  Fuse 9, through the clutch interlock switch, pin 114 in BCM, but also t-off to the IPDM connector E6 pins 30/72 (green wire) should be 12v with clutch depressed 0v with clutch upimage.png.67fbcd466337973cfdbc99bca8868d23.png
Edited by Keith D
2 hours ago, Keith D said:
Hi Keith. Thank you so much. I am the worst with diagrams looking here and in the element E6 there is no 30 /72.On my photo you think it is this green wire top right?
Update
For me it was luckily burn fuse in the box near clutch there was one 10v burned changed it and i got the power to the clutch sensor ;) So many fuses in this car, I was focused on power board near the battery, Happy days! Thanks Keith!
