E Gurl Posted February 26 Posted February 26 Hi All, Been a while since I posted anything, but was hoping for some advice or guidance. My imported 2003 350z recently failed its MOT on front control arm ball joints...amongst other things. I ended up purchasing new Dorman upper control arm assemblies L (521-605) & R (521-606) and seating cones (40173-AL500), but they dont fit the knuckle. Control arms fit the subframe fine. Where have I gone wrong? Thanks in advance for any help Quote
ZMANALEX Posted February 26 Posted February 26 All parts are in stock for your 2003 JDM. From the schematics below, please confirm what parts you require. Quote
E Gurl Posted February 26 Author Posted February 26 Thanks Alex It would be 1 on the upper image I'm heading over to the garage shortly to get some pics because they've only described the issue over the phone and the parts should be compatible as far as I can tell Quote
Adrian@TORQEN Posted February 26 Posted February 26 8 hours ago, E Gurl said: Thanks Alex It would be 1 on the upper image I'm heading over to the garage shortly to get some pics because they've only described the issue over the phone and the parts should be compatible as far as I can tell Hi, 1 is the correct part you ordered and received: 40173-AL500 Quote
E Gurl Posted March 11 Author Posted March 11 It is indeed and thank you to coz and the team for the support and quick responses. Just to close out the thread, I did have the right parts in the end and it was an issue of user error. 🙃 Quote
