350z 2005 struggle starting engine and Traction warning lights help please!
hi all I'm having a long winded nightmare with my 2005 DE,  3 weeks ago dash rev gauge decided not to work and all warning lights started flashing, also wipers stopped working this slowly fixed itself but the starting and engine and traction warning lights have stayed on along with struggling to start. i took it the garage that reset the ECU and found that fault for the throttle body, after waiting 2 weeks for get a new OEM one and fitted, I'm back to a car that struggles to start and the 2 warning lights on. plus know when i let off throttle the car randomly holds at 1500 RPM for a second. any advise would be much appreciated as i don't really want to keep  straining to car to start! thanks Tom
Hi Tom,
Get a cheap but good OBD reader from Amazon and read the errors yourself, rather than going to a garage. Possibly the camshaft or crankshaft sensors, but could be many more things. Check brake fluid level as well. Post the error codes here once you got them.
