4 hours ago, welshboyo said:
I just had a quick luck they said it was being discontinued and to use motul gear oil instead . Is that gear oil okay to use mate ?
The motul 75W-85 from Tarmac is what I use with some molyslip in too. The OEM oil is hard to find these days, but they're the same grade and viscosity so should be fine.
Yes that's fine to use buddy. As above maybe add a little molyslip for a little added lubrication. :thumbs:
