JDM OBD... ....... HELP !!!
Hi guys, ok, so car is not running good, fine on startup but starts missing when warmed up so it's parked up again.
I have tried two wired scanners that claim to do JDM but don't work and have a Bluetooth Elm with the idea of using NDS II.  That's no worked either...
Ahv read loads of threads with no definitive answer (the Bluetooth Elm and NDS II was said to work, ahv E'd the NDS people case ahm doing something wrong).
Anyway, any help appreciated...
Would like to get the codes before I remove anything...
Cheers...
Both wired scanners said so, but there were both positive and negative comments on that, similar to the forum itself...
The bluetooth reader ah got to go with the NDS II was as advised to get by them...
You know of any that work?
  • 6 months later...
