chefey Posted December 17, 2018 Posted December 17, 2018 Sometimes when closing doors one of the windows lowers halfway, can be either window, does not do it every time, nothing is caught in window. Is it some kind f safety thing or do I have a fault and is it an easy fix. Thanks in advance. Quote
ATTAK Z Posted December 17, 2018 Posted December 17, 2018 I would start by re-setting the windows Quote
chefey Posted December 17, 2018 Author Posted December 17, 2018 Thanks ATTAK .... I have a manual I downloaded, I believe it tells you how to do it. Quote
chefey Posted December 17, 2018 Author Posted December 17, 2018 ATTAK.... You are a star, battery was off car earlier in the year, so that is probably what caused problem. It would only do it every couple of weeks, but sure that was what caused problem. Will go and reset them later. The manual I downloaded is not the easiest to use, would have been on an eternity to find that, I wonder if it would even have had that reset cure. Thanks very much, you are a true gent. Quote
