taybo
Cylinder 4 misfire! 2006 rev-up
Got a P0304 code on a journey the other weekend and car was running rough. Changed the spark plug and coil pack and the same code keeps coming back. Plug was oily when I removed it. Thinking it's something serious now. Any help appreciated.
Share this post
Link to post
I had multiple failures on a cylinder and swapping coils didn't work until I put a good new coil in with lots of dielectric grease. Ran it very hard since with no probs. Might not be your solution but its a cheap try... Good luck
Share this post
Link to post
A common fault on the engines is the rocker cover grommets failing and letting oil past into the spark plug tunnel. Take the coil pack out and shine a torch down to see if any oil has collected.
Share this post
Link to post
I swapped the spark plug and coil pack for new items but no different. I think I'm going to book it into the local Nissan dealership for a full diagnostic :-(
Share this post
Link to post
Don't want to scare you, might not be the issue at all but this page talks about the fix for the leaky grommets. Might be worth a little read through
Good luck!
Share this post
Link to post
Loading...
350z-uk.com
370z-uk.com
350z-uk.com
370z-uk.com
