JackD Posted July 27, 2018 Share Posted July 27, 2018 (edited) Hi all! Just looking for some advice on getting cats put on my car. I have a manzo exhaust system and not to sure if the standard cats would fit, if anyone knows of a sport cat that I could use or would I have to have it cut and welded. Sorry im not very good when it comes to this! Ill post some some photos of what I can see from underneath the car. Thanks for for all your replies in advance!! Jack. Edited July 27, 2018 by JackD Quote Link to comment Share on other sites More sharing options...
scobie140 Posted July 27, 2018 Share Posted July 27, 2018 Its does look pretty similar size and layout to the standard exhaust so you might get away with OEM cats. Best bet would be if someone local had a spare or old cat they could lend you and you could take your decat off and compare them side by side before you commit to buying Cats that won't fit. 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 27, 2018 Share Posted July 27, 2018 OEM cats should fit, however remember that DE are different from HR. 1 Quote Link to comment Share on other sites More sharing options...
JackD Posted July 27, 2018 Author Share Posted July 27, 2018 Thank you both for your replies! Really help. I will I'll look out for DE OEM cats on the forum as hopefully that will be cheaper then paying for someone to weld them on! Thanks again! Jack. Quote Link to comment Share on other sites More sharing options...
