Lifesabeach26 Posted April 11, 2018 Posted April 11, 2018 Hey Guys, Below was an issue I had a few months back, the car wouldn't go into gear - it was bled and then worked again. This morning the car would not go into gear again! On top of that, I had the car services a few weeks ago at a garage, the MOT is due next month and he suggested advisory's. He said only the LED needs to be changed to pass MOT. - headlight LED needs replacing - Power steering is really heavy, keep an eye on it. So the power steering has got a lot worse and turning the wheel when driving is now a chore. Not only that, whilst turning the wheel (being stiff) it will sometimes loosen up again and the car will turn quicker. (feels dangerous) So in short, unfortunately I have had some issues with my first 350Z and the hassle is too much. I'm looking for ideally a specialist that can assist / advise / fix these issues around my area (Redditch, Worcestershire) as the car currently cannot move off my drive so I am stuck with distance. Then once fixed I will be selling - it was only there for a bit of fun but it has put me off. Any help would be great! Thanks all! Quote
ZMANALEX Posted April 11, 2018 Posted April 11, 2018 Sounds like a PAS pump failure and also the clutch slave cyl. What year and model is your car? These are normal wear and tear items on the 350 and not too disastrous. Quote
Lifesabeach26 Posted April 11, 2018 Author Posted April 11, 2018 Hello, thanks for the response. Year is 05 and 350z Rev up I believe It is getting recovered Friday now Quote
ZMANALEX Posted April 11, 2018 Posted April 11, 2018 That should be a fairly cheap fix. New slave, line and fluid is less than £100.00 and a preowned PAS pump will be circa £50.00. A couple of hours labour and you should be good as new. Quote
Lifesabeach26 Posted April 12, 2018 Author Posted April 12, 2018 Oh that’s a good sign, you’ve made me feel a little more confident! Thank you! Quote
