Dannyg Posted December 12, 2017 Posted December 12, 2017 Hi All ive got multiple O2 sensor error codes coming up, but its not the sensors at fault my garage reckons it could be something to do with the wiring and suggested they carry out a pin-out test, i have found info on what each pin does, and a diagram but my garage have said there is no Bank 1 sensor output pin would something like this be on the main ECU wiring diagram? has anybody had this before? and can any body point me in the right direction thanks Dan Quote
ZMANALEX Posted December 12, 2017 Posted December 12, 2017 What codes are you getting? Also what year and model is your car? What adverse running issues are you having? Quote
Dannyg Posted December 12, 2017 Author Posted December 12, 2017 Hi alex Getting p1166 p1167 and p1273 codes 2004 - humpy and chris Gs old car Cars running fine just exhaust smells a little Dan Quote
Dannyg Posted December 16, 2017 Author Posted December 16, 2017 On 12/12/2017 at 16:25, ZMANALEX said: What codes are you getting? Also what year and model is your car? What adverse running issues are you having? Just been going through original build on this car and read that it has berks hfcs on it, so its actually a common fault, will a remap get rid of the eml light for these codes? Quote
ZMANALEX Posted December 17, 2017 Posted December 17, 2017 If it is the Berks that are at fault then an up rev should fix the problem as they can be turned off when doing the tune. Quote
