Suffolkz Posted July 11, 2017 Posted July 11, 2017 (edited) Hello all, My front discs need replacing, and the garage I use have quoted £140 for the discs and £38 for the pads (labour extra), both Brembo. Research online would suggest this is reasonable - I wondered if I should stick with the Brembos, or whether you enlightened chaps / chapesses would recommend a different manufacturer? Edit: I only use the car on the road (no track use). Thanks in advance, Suffolkz Edited July 11, 2017 by Suffolkz Quote
coldel Posted July 11, 2017 Posted July 11, 2017 Whole sub forum on brake options, quite a few recent discussions also https://www.350z-uk.com/forum/53-brakes/ 1 Quote
Suffolkz Posted July 11, 2017 Author Posted July 11, 2017 Thanks - I'm in a habit of using the 'search' on the general forum, i forgot to check the technical section. Moderators: feel free to move this thread if necessary. Quote
Exec Posted July 15, 2017 Posted July 15, 2017 I got mine done about 6 months ago and considered going with aftermarket dimpled and drilled disc but got brembo discs and pads for the same price as you if I remember. 1 Quote
