Tow hook thread
Rshep1
I'm wanting to make a bracket for my front plate that will screw into the tow hook in the front. Am i right in saying the tow hooks are an m22 for the later models?
Also if anyone can point me in the direction of any brackets that do fit the towing eye it would be much appreciated
Although I've heard of the ones in the boot not even fitting :lol:
Ideally measure the hole, but I think the only options are 16 or 22mm, so measure the hook you've got and see if it fits. if it doesn't, then you want the other size.
When I was looking for one I found that 22mm was a bitch to source and the ones that did exist were silly money.
You can get adapter thingies though (can't remember the technical term) that will increase the size of the tow hook to fit the hole.
