RichKitch Posted October 5, 2016 Posted October 5, 2016 Can anyone help with a set of the longer bolts and spacers required when you plonk a plenum spacer in? Or can anyone tell me the dimensions of the bolts and spacers I require? Maybe then I could source them if I knew the spec. Cheers Rich Quote
RichKitch Posted October 5, 2016 Author Posted October 5, 2016 Should come with the spacer mate. Yup -they should have! Unfortunately they have gone walkabout. Quote
kayjay0_7 Posted October 6, 2016 Posted October 6, 2016 (edited) On the 5/16" kit the bolt length is M10 x 1.25 x 30mm Spacers are 6mm thick Edited October 6, 2016 by kayjay0_7 Quote
kayjay0_7 Posted October 6, 2016 Posted October 6, 2016 (edited) Measured the spacers , they should be 6mm thick Edited October 6, 2016 by kayjay0_7 Quote
Payco Posted October 6, 2016 Posted October 6, 2016 PM ZMANALEZ. You cant afford to get this wrong as they need torqueing and be the correct length. Quote
RichKitch Posted October 6, 2016 Author Posted October 6, 2016 Thanks guys - this is really helpful. Rich Quote
Jon T Posted October 6, 2016 Posted October 6, 2016 If you get stuck I will probably have suitable bolts laying around, uinlikely I'll have the spacers though. Thanks Quote
RichKitch Posted October 6, 2016 Author Posted October 6, 2016 Thanks Jon. Tarmac has offered to sell me a plenum spacer fitting kit. I'll not use most of it, but it's all genuine and 100% the right bits. Cheers Rich Quote
