Help Anyone with Consult III Plus?
I swapped out my clockspring to try and fix a problem with my cruise control not working. Unfortunately I now have my VDC off and my slip light on.
Is there anyone near Birmingham or Stafford that could reset my steering wheel angle sensor? Obviously I would be willing to pay.
  • 1 month later...
I was in the same position and downloaded and purchased Nissan Data Scan and using a Vagcom KKL OBD Adapter and Nissan Datascan I was able to reset the angle sensor and resolve the issue.
You'll find purchasing the Nissan Data Scan and cable cheaper than paying someone else or taking it to Nissan.
Sent from my Xperia Z2 using Tapatalk
Also, you did replace the clockspring with a genuine part didn't you? Not an Ebay special?
Yes, turns out I needed to reset my steering angle. Did it using Nissan data scan.
Glad to hear its resolved Fluke.
Just wanted to check about the replacement part as I had a nightmare with my clockspring replacement 😄 Happy Zedding!
