SwissZ Posted July 11, 2016 Posted July 11, 2016 Guessing this doesn't happen often as a forum search came up with nothing, but it was 'melt your face off' hot in Zürich today and the Z was showing 20° C. Was about to close the roof as I thought its getting a bit cool but then I thought, as my face was melting off, I'd hit the aircon button instead. I'm assuming the sensor's faulty, so my question is: Where is the sensor and can I replace it myself? Or... Is there some reset procedure for it? Pedal dance, holding seven buttons down at the same time, etc Cheers Quote
350zedd Posted July 11, 2016 Posted July 11, 2016 Its mounted on a small bracket below the bonnet catch next to the horns. I'm assuming its a thermistor type so as the temperature changes so would the resistance also. You could measure this with a multimeter (ohms) but as I dont have any lookup tables, can't tell what the resistance should be against a given temperature. Sorry thats all I know. Quote
Bigjimg Posted July 11, 2016 Posted July 11, 2016 https://www.rockauto...c=1431964&jsn=8 Thats what the sensor looks like if that helps, did mine about 3 months back, very easy diy job. And it is where 350zedd said. Quote
