Alex350z Posted June 20, 2016 Posted June 20, 2016 Managed to split a hard line that connects to the calliper when changing a front disk. Its leaking from where it connects from the calliper to the rubber joint that sits in a bracket. How can i stop it dripping and what should i do? I go to the nurburgring thursday!! Quote
Richf Posted June 20, 2016 Posted June 20, 2016 A garage should be able to knock something up for you quickly and cheaply Quote
Alex350z Posted June 20, 2016 Author Posted June 20, 2016 Its the hardline though, and obviously i cant drive my car to take it to a garage Quote
Alex350z Posted June 20, 2016 Author Posted June 20, 2016 No i dont think they do, funnily enough i have braided lines on the way but the post office has lost them, im not having any luck! Quote
Richf Posted June 20, 2016 Posted June 20, 2016 Its the hardline though, and obviously i cant drive my car to take it to a garage No but you can remove the hardline and they can use it as a pattern The braided kits dont replace these parts Quote
Alex350z Posted June 20, 2016 Author Posted June 20, 2016 I cant even remove the hardline as the studs are that rusted, im scared they are going to round. Any ideas? Quote
Rob332 Posted June 20, 2016 Posted June 20, 2016 You will need to remove the damaged pipe. It will need to be replaced if it is split. If the unions are starting to round, your best bet would be to get lots of penetrating oil on them and get yourself some brake pipe spanners. A garage will be able to make up and flair a new pipe for you, but as Rich says, they will need the old one to get the measurements and bend points from. Hope you get it sorted. Quote
Alex350z Posted June 20, 2016 Author Posted June 20, 2016 Ive cut the pipe, bent it over and flattened the end to attempt to stop it leaking. Having new front pipes made . Panic over, haha Quote
