Robz350z Posted June 10, 2016 Posted June 10, 2016 Hi guys, not long picked up my new(to me) 350z, but I've got no washers front or rear, and no headlight wash either! Sure this is a fuse issue, but does anyone know which one it is in the 3 boxes? Thanks in advance, love the car might I add. Quote
GMballistic Posted June 10, 2016 Posted June 10, 2016 I believe the fuse for the windscreen washers is in the drivers footwell fuse box. I can't be 100% certain of that though as I have sold my Zed, ...if you have the manual for the car though it will be in that. Just look at the index in the back for fuse locations. 1 Quote
Robz350z Posted June 10, 2016 Author Posted June 10, 2016 I've had a look in the drivers footwell, and nothing looks obvious. Quote
GMballistic Posted June 10, 2016 Posted June 10, 2016 I've had a look in the drivers footwell, and nothing looks obvious. If I still had my Zed I would check for you. Does it have a sticker on it (as below) on the fuse box lid in the drivers footwell? ...if so have you checked the fuse marked "Washer"? There are 3 fuse boxes on the 350Z and if it's not in the drivers footwell then my second bet would be the fuse box in the engine bay in front of the car battery. Locations are in this thread for you here: http://www.350z-uk.c...-box-locations/ Oh and welcome aboard. 1 Quote
Robz350z Posted June 10, 2016 Author Posted June 10, 2016 Huge help, thanks for that! I'll recheck them ASAP. 1 Quote
Robz350z Posted June 10, 2016 Author Posted June 10, 2016 My fusebox in the footwell is different, no fuse marked washer, that is the start signal fuse in mine?...very odd. Quote
GMballistic Posted June 10, 2016 Posted June 10, 2016 My fusebox in the footwell is different, no fuse marked washer, that is the start signal fuse in mine?...very odd. Hhhhmm, is yours a UK Zed or JDM? What's the year etc? And again do you have a car manual from when you bought the car? Quote
Robz350z Posted June 10, 2016 Author Posted June 10, 2016 Mine is a 2004 uk Zed, manual doesn't help. Quote
GMballistic Posted June 10, 2016 Posted June 10, 2016 Took me awhile to find this but I think we might be getting somewhere. It sounds like the washer fuse will be in the most awkward of the 3 fuse boxes I'm afraid. It's the one just slightly under the scuttle panel near the battery according to info in the thread below. This thread: http://www.350z-uk.com/topic/71948-where-is-the-washer-jet-fuses/ Sorry as I said I don't have my Zed anymore so if I did I would have just checked for you in the first place. I hope that's it. 1 Quote
Robz350z Posted June 10, 2016 Author Posted June 10, 2016 That's great info, I'll have to check the most awkward one tomorrow. Many thanks again, much appreciated! Quote
Robz350z Posted June 11, 2016 Author Posted June 11, 2016 OK, checked the offending fuse, and it looks like it's been changed before, and it hadn't blown. Changed it anyway, and they still didn't work, but after a free goes, the rear is now washing! The front or headlight washers are still dead though, very odd. Quote
Robz350z Posted June 11, 2016 Author Posted June 11, 2016 Update:- Headlight washers are working now too, that was only down to my stupidity, I thought they worked with the front washers, didn't realise it had its own little button! Still no front washers though, think it could be the dreaded blocked non-return valve? Quote
Robz350z Posted June 11, 2016 Author Posted June 11, 2016 Update 2:- Took the pipe off at the non-return valve, and nothings coming through, looks like the pumps had it :/ Quote
GMballistic Posted June 11, 2016 Posted June 11, 2016 Okay then Rob that's good to read, ...front washer pump is the cheapest of the lot & is fairly easy to replace as well. Clark Motorsport are your best bet for this part (cheapest I know of): http://www.350z-uk.com/forum/207-clark-motorsport/ On their website: http://www.clarkmotorsport.co.uk/parts/Windscreen-Washer-Pump/488700010 And here is a short guide on how to change it: http://www.350z-uk.com/topic/59243-how-to-change-washer-pump-motor/ 1 Quote
Robz350z Posted June 12, 2016 Author Posted June 12, 2016 Cheers again. I've got one on order now, hopefully an easy fix then. Quote
GMballistic Posted June 12, 2016 Posted June 12, 2016 Should be easy enough although you might get a little wet as changing the pump will empty whatever's left in your washer bottle. Quote
Robz350z Posted June 12, 2016 Author Posted June 12, 2016 Quite true, I'll run it out as much add I can. Thanks again, you've been a great help Quote
