SpeckUK Posted June 9, 2016 Posted June 9, 2016 (edited) Hi Guys, as the title says, sometimes in my 2003 350z the cubby door seems a little broken?? and doesn't want to open when i press the button any one know how to fix this? or is it just a nissan gimmicky thing cheers Edited June 9, 2016 by SpeckUK Quote
GMballistic Posted June 9, 2016 Posted June 9, 2016 Mine used to do this occasionally, ...I found that making sure I pressed the button in slightly harder for a second got around it. Otherwise maybe try a tiny squirt of WD40 behind the button/on the latch mechanism to see if that helps. Quote
SpeckUK Posted June 9, 2016 Author Posted June 9, 2016 yeah thats what ive been doing and keep thinking i'll break it one day! Quote
GMballistic Posted June 9, 2016 Posted June 9, 2016 Then maybe try the WD40 using the "red straw" behind the button to see if it helps. Quote
PageyUK Posted June 10, 2016 Posted June 10, 2016 Mine does the same, I think the plastic catch doesn't retract fully. If you push the top of the door whilst pushing the button it opens. Quote
