Weeping coolant pipe to oil cooler
I was replacing the oil pressure sensor yesterday and noticed the oil cooler coolant pipe was weeping slightly. How dangerous could this be to drive until fixed, if the pipe failed would I loose all coolant? Can the pipe be replaced without doing a full coolant drain or patched up until I can take it to a garage?
Should be okay until you get it fixed, however if it fails then you will empty your engine of oil, that is if you are referring to the engine oil cooler.
If you are referring to the OEM coolant sandwich plate then if this fails you will run out of coolant.
