Fitting a vortech v3 for a g35 to a 350z
Hello
I'm contemplating going FI and I've found a g35 kit that's a good price.
Am I right in thinking it's just the SS Box that needs changing over, for it to work properly.
Or is there a way of retuning the g35 SS, or any other options?
Tom.
Amazing that's what I was hoping .. All the info I found was really dated.
So if I took the kit fully installed but not connected (still running NA) to a tuner they can just connect the supercharger up and tune it on uprev on the stock ecu?
Tom
Posted (edited)
If you adding bigger injectors, fuel pump and all that - you better get a base map sorted to get you to full mapping session.
Speak to Abbey Motorsport, Horsham Developments etc for best advise.
Edited by Vlad
Yeah I plan on adding those aswell as an oil cooler and an oil pan spacer .. is a fuel return system essential as I get mixed search results for this?
Posted (edited)
For the best results i would definitely get one. If you not aiming for over 500hp, i think CJM Stage 0 (S0) will be enough.
Edited by Vlad
If you are aiming for around 400whp you will be fine without a RFS.
You just need a walbro 255lph pump installed in a modified OEM fuel bucket bigger injectors and FPR though you could omit this.
I've got an OEM fuel bucket I'll be happy to sell which I could do the necessary mods for you before dispatch and can also fit the pump for you for plug and play solution.
Yeah 400whp would be the goal.
And it's for non rev up engine. So should be all good on the fitting side.
Tom.
