Tail lights not working help needed.
on my 2005 de. Rear lamps not working including the number plate light. I press the brakes and the brake light comes on but not the tail lamp with the front headlamps. The fuse box by your feet has a stop light fuse red 10 amp. Changed this and new bulbs and still no joy. Is there another fuse bay for the rear lights???
Cheers.
You've just had your rear bumper off so are you sure you haven't pinched or caught a wire on something or forgot to reconnect a plug etc?
Posted (edited)
its getting late but if i remember correctly theres a fuse for rear lamps in the fuse box in the engine bay.
there are 2 fuses in the fuse box.....try checking number 80 a 10A and number 73 a 15Amp
Edited by buster
if its not these try checking fuse number 71 in the IPDM fuse box...this is located next to the battery and is know as the hidden fuse box.its a right sod to get to and your need to remove the battery cover lid,surround etc
good luck and hope this helps.
AHA. Yes Buster. Remember now. If i'm right the fuses are located like underneath rather than on top of the board. Ill have a good look tonight. Thanks guys.
