[SOLD]Direct Fit LED 4th Brake, Rear Fog Light, Reverse Lamp For 2009-up Nissan 370Z
https://instagram.com/p/4UJt-ABc1m/
https://instagram.com/p/4UJxrPhc1w/
Compatibility
2009-up Nissan 370Z
Features
Replacing OEM part 26582-3GY0A
Powered by 8 pieces high power SAMSUNG LED lights
Replace light-less rear center bumper reflector to LED taillight/backup light
4 pieces red LED lights for the 4th brake/tail light (aka rear fog light)
4 pieces white LED lights for backup reverse light
Give your 370Z a JDM Fairlady Z look just brighter and better
Direct replacement with some wirings required
Additional Information
If you're still blacking out the stock rear reflector i have a solution for you! Introducing all new Nissan 370Z LED rear fog light/backup light that converts the lightless center bumper reflector into a tail light, brake light, and reverse light all in one.
This LED assembly is compatible with 2009 and up 370Z and is inspired by the 2015 GTR where the LED Tail light and brake light is designed so that you don't actually see each individual LED. Rather, you get a fluid, continuous output.
There are 4 pieces of Samsung LED in the center function as reverse lights and a surrounding red LED border for the tail light and brake light.
This is the latest LED technology you will see on many new cars for their tail lamp designs, which gives your 370Z a nice JDM Fairlady Z look, just brighter and better.
£125 including recorded delivery
Edited by rich370z
Hi, the brake light still has a reflector within it so your not losing anything just adding a further brake,reverse and fog light.
Thanks richard
