D1 spec throttle controller help
Marti350z
Just received nine today, now I received the unit itself and the lead which is suppose to be specific to the Z.. Now this lead doesnt fit my car, it fits into the pedal plug but not the other part, can anybody confirm if this is the wrong/right lead as the company I bought it off swear blind it's the right one.. Cheers d2d52a0a79963c6252e6a1ced9dcdaef.jpgb2783acba613e573cde269c698311757.jpg
So it just got very serious, just went to drive my car, and nothing car won't start, tried to plug the diagnostic machine in and there's no power to the port.. With the ignition on if I press the throttle I can't hear anything, should I be able too?
Hi, had the same issue with mine when i bought it. Its the lead with the white bit sticking out that doesn,t plug in isn,t it. Tried for ages to get it to fit. In the end i attacked the plug and yanked out the white cradle ( the bit sticking out of the plug ) fitted a treat after that.
Edited by alanm
I had the same problem, till I realised you need to remove the white bit, you'll need to do a ecu reset, if the engine warning light is on, there's a guide on here and on the net how to do it. Just be patient it's all about timing, good luck!
Edited by Pinoy-R
