hi i have just fitted a wireless reverse camera to my 06 350z gt but it makes a quiet static noise whenever keys in ignition.
its wired positively to the main power for the headunit. its some touch screen double din. no idea what make.
its earthed at the earthing point behind the radio.
video output is fine, then it goes abit grainy after a bit.
im thinking i could have a bad earth? or am i completely wrong?
thanks
I have had one on test for 6 months and have had the same issues.
Graining, colour problems and interference.
Tried different aerial positions. power source. and earths etc etc
Still get interference occasionally no matter what..
Going to hard wire it and get rid of the wireless side when the weather gets better and see if its the camera or not.
I have a hard wired reverse camera fitted, as I have experienced the wireless type on previous cars, and everybody I knew that had those fitted complained about them.
It's not that hard to fit a wired one. Just remove the internal plastics in the right order and run the cable in. You've only got to do it the once and you'll reap the benefits.
