Jixaman Posted June 3, 2014 Posted June 3, 2014 Well, finally got round to reading the codes, I guessed it right... P0340 - Camshaft position sensor problem (B1)... Shows the good info posted on the form lead me down the right route... Got 2 ABS fault codes too but there possibly symptom of the first one... C1109 - Battery voltage out of range... C1130 - Engine 1 fuel cut system fault.. Just thought I'd post, now to research a) where is it and where to get one... No rush, ahm skint on the account of goin racin wi the wee man... It costs a fortune just to be a pimple on the arse of it... Quote
Jixaman Posted July 2, 2014 Author Posted July 2, 2014 Ok, so just getting round to fitting the sensor (big thanks to Ewan @ Clark Motrsport)... Excelent access, easy to get out, fluggered if I can get the little green plug off the back... Have pushed the little slide all the way forward and it still wont come off... What am I doing wrong? Cheers... Quote
Jixaman Posted July 2, 2014 Author Posted July 2, 2014 KEEP CALM and just cut the wires... Ok, so Google search and sore fingers later, you think, why, surely theres a better way... Anyway, job done all lights out (reset codes) and we'll see how it goes... Quote
andybp Posted July 2, 2014 Posted July 2, 2014 a lot of people change these out i had a look at mine when i got this code pulled the connector off and it was corroded sprayed switch cleaner on it,and it's been fine for the last year so far Quote
