Need Advice with Import Lower Control Arms
So i took my car into the garage to get the camber adjusted and tracking done since fitting my coilovers and they have told me that there is play in the front caused my the bush being damaged in the lower control arm.
The problem now is that because my car is an import there is no aftermarket options apparently and that the UK spec lower control arms wont fit onto my imported Z?
Does anybody know if this is true or even where to get some import spec lower control arms asap?
Many thanks!
Who has told you they are different? Drop me a PM with your registration number and I will check for you
Nissan dealers in s****horpe mate, someone has just gave me your website this sec too. ill message you now, thanks!
