bizz Posted April 14, 2014 Posted April 14, 2014 Hi All, I'm after a quick bit of info.... Does anyone know the operating voltage of the fuel level sensor in the 350? Is it 5v or 12v?? Thanks for your help Bizz Quote
Tricky-Ricky Posted April 14, 2014 Posted April 14, 2014 Fuel level sensor is resistance based not voltage. Quote
richmillions Posted April 14, 2014 Posted April 14, 2014 It will have a voltage supply, for example on the Ford fiesta it has a 5v reference supply line fed from the cluster. No idea what it is on the zed unfortunately. Quote
Tricky-Ricky Posted April 14, 2014 Posted April 14, 2014 The sender doesn't need a voltage its just a variable resistor, check the manual, the display however I would suspect does have a voltage supply. Quote
