I've replaced the steering wheel and for some reason when I took it for a test drive got about 10 yards and the tlc light came on and it's fully disabled traction control. Any ideas?
I am not 100% sure (its ESP) I image that there is a sensor in the steering wheel which is used to tell the BCM the position of the steering wheel if that's not there then the system would likely go into fault i.e. switching ESP off.
Somebody may correct this as I haven't had any experience with the Z, but as a Controls Engineer I would image something like above.
Regards
Regards
sounds feasible to me, the traction control looks at speed, steering angle etc so it suggests it may not be getting a signal it expects
steering wheel has to be inline with the groove /marker point on coloum shaft and steering wheel hub....if slightly out the light will come on and the t/c will engage and some fun points as well.....best remove the wheel and doudle check m8....had this happen the first time i refit mine.
hope it helps.
