CavemaN1010 Posted February 2, 2014 Posted February 2, 2014 HI Not often on here but im a man in desperte need my 2005 import has been up to now very reliable but i go to start it after work and it just keeps turning over but not fireing, had the RAC man out and he could not connect to the cars computor, so i have a couple of questions 1... never noticed before but when you turn on the ignition does the cooloing fans kick in straight away as they are at the mo 2... can you normally hear the fuel pump pressurise as you turn on the ignition as the RAC man seemed to think you could 3... he sprayed easy start up the air filter and it still didnt try to start so could that mean its not fuel related I know its probably impossible to diagnose like this but im after ideas or if i get really lucky someone may have come accross this problem before either way any help will greatly recieved thanks Mike Quote
Harryjax Posted February 2, 2014 Posted February 2, 2014 Sorry to hear your having trouble. Buy yourself a code reader and see if any fault codes are stored. Have you checked to see if you've got spark fr the plugs? Worth a try even if it is just to eliminate. Quote
350 Russ Posted February 2, 2014 Posted February 2, 2014 if you do buy a reader make sure it works with Jap imports, they have JOBD instead of OBD2 which is why the RAC man couldn't connect to it. Quote
CavemaN1010 Posted February 2, 2014 Author Posted February 2, 2014 if you do buy a reader make sure it works with Jap imports, they have JOBD instead of OBD2 which is why the RAC man couldn't connect to it. this is very helpfull thanks i have looked on ebay and they range in price a lot will they all do the same ?? Quote
