andyvvc Posted January 2, 2014 Posted January 2, 2014 (edited) I posted a thread a while back about using the peddal-dance to get the CEL code to 'flash' on the screen. I've finally managed to get it properly checked and it's come back as "A/F Sensor 1" being faulty. My car is the HR engined twin-intake. I have a Stillen Gen 1 fitted *years* ago, and the CEL came on about 3 months ago. As a result, i reset the ECU. 200 miles later the CEL came back on. Suspecting it might be MAF related i took them both out, sprayed them carefully with carbon cleaner and allowed it to evaporate. I repeated this and also gently swabbed the fillaments with a cotton bud while wet with cleaner. Refitted to the car, did the ECU reset and......300 miles later the CEL came on again I think i might genuinely need a new (or re-conn'd) MAF sensor.....anyone know which one A/F Sensor 1 is...I'm assuming the one on the left when opening the bonnet? I also suspect Ni$$an charge £350+ for the part EDIT - full details from the paperwork on the fault: Code P2A03 - A/F Sensor 1 (B2) Edited January 2, 2014 by andyvvc Quote
R35LEE Posted January 2, 2014 Posted January 2, 2014 I have them sat in my cupboard along with 370z ones 1 Quote
jell367 Posted January 2, 2014 Posted January 2, 2014 · Hidden by glrnet, January 2, 2014 - Possible banned memeber Hidden by glrnet, January 2, 2014 - Possible banned memeber I've got a spare if you want it Andy, can meet you somewhere tonight if your in a hurry or at the weekend. It's from a DE engine but FOC.
andyvvc Posted January 8, 2014 Author Posted January 8, 2014 The two MAFs arrived at work on Tuesday, cheers Lee! Will be fitting them at the weekend. Quote
