Plenum spacer help guys
Dan-s14a
Yup that's a Motordyne and yes they degrade and technically fall apart. You need to make sure the gasket surrounding the spacer is intact and will place a good seal otherwise you may as well throw it away. Did you buy this off the forum cos that's on shocking condition.
If you fancy replacing that spacer just give me a nod as I supply new and improved spacers to the community. Also anodised to a colour of your choice.
