air con won't turn off ?
Hi every one ,
As above I had this problem for 3 month now and can't figure it out .
Every time I put the controler on "off" position the air still come out heavily like when you put it on "auto". Position so I have to put the fan on lower speed all the time , and when I press the AC bottom it works fine ! I went to my local garage to refil the gas but he said it won't resolve the problem its somthing to do with the "controler resistant "!! And I have pm zamanalex but no reply still ! So any suggestions guys ?
if the stereo has been changed or someone has had the dash out then they could of trapped the ribbon cable that links to the heater control unit. Yes you can check it yourself. Check in the guides section. Probably look for changing stereo thread and it will show you how to get to it
Sounds like the ribbon is either faulty or not plugged into the back of the dash/dial controls.
If its unplugged it'll blow continuously until you plug it in.
