Rajzed Posted October 2, 2012 Posted October 2, 2012 Hi everyone! The first problem has occurred.. I've literally had my car for less than 2 months and I think my steering is progressively getting worse. Everytime I brake, the car steers to the left! I even tried releasing the steering wheel on level ground whilst driving (don't worry I wasn't going too fast!) and it seems to go relatively straight but then the smallest bumps in the road makes it gradually turn left! It's always going left! Any ideas on what could be the contributing factors? I want to get it up on axle stands within the next couple of days, anything I should look for?? Thanks in advance everyone! Kind Regards, Raj Quote
Chris AME Posted October 2, 2012 Posted October 2, 2012 What tyres are you running and are pressures set correctly Quote
marzman Posted October 2, 2012 Posted October 2, 2012 Agree, check your pressures. Even a 2 or 3 psi drop on mine is noticeable. Quote
ThriftyFifty Posted October 2, 2012 Posted October 2, 2012 Agree with the checking of pressures. My car was pulling to the left quite a bit, found out the front left was 27! Right was 33. It is still pulling slightly, but it's much improved since then. Quote
