spawn Posted May 18, 2012 Author Posted May 18, 2012 Have you done the resets in order and properly? It took me about an hour or 2 to do them Yes ive done all 3, although the first one is hard to tell if its done anything, because you get no indication of anything, the second one you can hear the flap move, and the third you know has worked when the cel is flashing. Quote
Dblock Posted May 18, 2012 Posted May 18, 2012 Number 3 it should be flashing then solid. What rpm are you idling at? Quote
spawn Posted May 18, 2012 Author Posted May 18, 2012 Number 3 it should be flashing then solid. What rpm are you idling at? Yes then release pedal within 3 secs. Idling around 800 after reset, when driving and stopping at junctions holds around 1000rpm no higher, the throttle feels kind of weird? When say your coasting and put your foot on the throttle, it kind of does a soft jerk, it feels like the throttle is abit on and off?? and not smooth? It may just be a characteristic of the 350z? Quote
Dblock Posted May 18, 2012 Posted May 18, 2012 I know what you mean. But if your still getting the light it might be new TB time Quote
spawn Posted May 18, 2012 Author Posted May 18, 2012 Il disconnect battery 2moz and clear ecu, do all 3 resets after... and see? If it comes bk looks like it will be time for a TB. Quote
spawn Posted May 23, 2012 Author Posted May 23, 2012 Update! Fitted new (second hand) throttle body, fingers crossed its been fine since! Gave the car a good highspeed run 2nite and no eml light... So looks like the tps was to blame. Hopefully i can get on and enjoy the car now Quote
Dblock Posted May 23, 2012 Posted May 23, 2012 Ah good news May the force be with you May the 24th be with you? Nah il get my coat Good to hear you sorted it Quote
Zhorno Posted November 16, 2013 Posted November 16, 2013 Mine has just came on ... Iv reset codes hopefully stays away other wise I'll be following this ! Quote
