The studs on a Zed have a thread which is M12x1.25, i.e. 12mm (approx. 0.47 inch) diameter and 1.25mm pitch (20.32 threads per inch). You will also need to know the seat that is suitable for your wheels, I believe that the 350Z 18" standard and Rays alloys use a 60° taper seat nut whereas the 370Z Rays 19" use a flat seat nut. You'll probably want to check but from what I can work out you'll want Nissan part number 999H1-A7009 or McGard 24154 for the taper seat, Nissan 999W2-JT000 or McGard 21153 for the flat seat.
I'm sure someone will be along soon to correct me if I've got any of that wrong!
