skidder Posted November 24, 2011 Posted November 24, 2011 I got my 54 350z welded at the flange today.On driving home it seems on a low idle, about 400 rpm(you can feel it needs to be higher).I got out the car and I can now hear hissing but not from the joint thats welded.I'm guessing they've cracked the exhaust somewhere? advice much appreciated. Chris Quote
Zugara Posted November 24, 2011 Posted November 24, 2011 best take it back and get it on the ramp to have a look see Quote
skidder Posted November 24, 2011 Author Posted November 24, 2011 I presume when warm it should idle about 800rpm? Quote
Zugara Posted November 24, 2011 Posted November 24, 2011 I presume when warm it should idle about 800rpm? Is it a hissing or a sucking Quote
skidder Posted November 24, 2011 Author Posted November 24, 2011 a constant hissing but not from where it was welded. cheers chris Quote
Zugara Posted November 24, 2011 Posted November 24, 2011 Have you opened to bonnet to see if its coming from the engine somewhere? Did the hissing get better or worse as the car got hot? Quote
skidder Posted November 24, 2011 Author Posted November 24, 2011 its definitely coming from underneath.Seems sort of around the same level whether hot or not.Just before I dropped it off I swear it was running about 800 rpm and never missed a beat.now seems to settle at 400rpm and doesnt seem to be happy at this level. cheers Quote
Zugara Posted November 24, 2011 Posted November 24, 2011 I assume the revs are stable and not hunting up and down If you can get underneath you should be able to find out exactly where its hissing from, perhaps the y pipe bellows have split. Quote
skidder Posted November 24, 2011 Author Posted November 24, 2011 No its not up and down.I'll try and get underneath and have a look. Quote
Zugara Posted November 24, 2011 Posted November 24, 2011 No its not up and down.I'll try and get underneath and have a look. see if you can take a sound/video clip and post up When I had no exhaust on mine for a few hours, my idle rpm was circa 800. Quote
skidder Posted November 24, 2011 Author Posted November 24, 2011 Any idea what is the rpm supposed to stabalise at? Quote
skidder Posted November 24, 2011 Author Posted November 24, 2011 Unbelievably it was the air-con off that was causing the low revs.Sitting nicely at 800rpm.Just took it out for a major blast and seems all good. Hissing is still apparent though.I'm pretty sure the garage took it for a spin though as my fuel trip computer stated 10 miles less than when I dropped it off, the cd player had changed discs and tracks, and the air con had been switched off.Blighters eh!! will investigate tomorrow. cheers Quote
