Jayp350z Posted November 8, 2011 Share Posted November 8, 2011 I've recently been getting a squeaky clutch pedal, usually when it's cold and wet outside. Iv put a bit of wd40 on it which helped a bit but didn't put much effort into it as I was running late for work. I also feel a couple of drops of water drip on my right leg just above my ankle which is making me think the leak is causing the squeak (hey that rhymes ) The problem is I can't find where the leak is coming from. It can't be too bad as its only a couple of drops as I pull off when the car has been stationary all night but ok during the rest of the day, even when it's chucking it down with rain. Has anyone else had this happen with theirs? Quote Link to comment Share on other sites More sharing options...
kriss Posted December 12, 2011 Share Posted December 12, 2011 Bump. I have a squeak on the clutch mid travel which feels and sounds like the pivot point Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted December 12, 2011 Share Posted December 12, 2011 WD40 will not do anything, get some white silicon grease and then get right underneath and get it right up onto the spring and pivot mechanism... A good soaking will sort it out lovely Quote Link to comment Share on other sites More sharing options...
