08+ Sat nav removal
Greekman
Its very easy to do and all the trick is in using a flat thin screw driver or a blunt knife (like i did). There are two bolts to unscrew but if you dont know what screw driver to use then dont try taking the sat nav out in the first place!!! :p:lol:
There is a plastic frame between the screen and the button pad. Squeeze the knife on the side (you can use a thin cloth as well so that you dont scratch the plastic) and it pops up.
Pick it up and remove it
Finally unscrew the two aluminium screws and thats it!
ps You dont have to undo the front clip in advance like the old sat nav! :thumbs:
