just a few questions....
Roo
Right ho....
Before I ditched my old car i ripped all the components out of it, but before I sell em I want to check if its worth sticking them in the zed. So a bit of advice before i even consider riping things apart..
Front component speakers -
What size are tweeters?
Do they run off the headunit or pre-outs to a slaved amp?
What is the rating (ohm and RMS/peak)
Where are the crossovers?
Are the bose better than Rainbow CMX 265 (kick varient if i remember correctly)?
Sub woofer -
Size? I have a JL V12W3D4 - would it fit? ( is it worth it)
Also equaly output rating?
And ran off head or are there pre-outs to a slave amp?
kit I have kicking about also includes genesis profile 4 and a JL monoblock as well as co-axial 5x7 but what happens to them depends on if i can use em.
lot of q's I know! any help or pointer appreciated!
What size are tweeters? Not sure but 1" ones can normally be made to fit the surround
Do they run off the headunit or pre-outs to a slaved amp? They run off the head unit or BOSE amp if you have one
What is the rating (ohm and RMS/peak) SOD ALL lol Even run of the mill replacements are a step up]
Where are the crossovers? They are built into the amp
Are the bose better than Rainbow CMX 265 (kick varient if i remember correctly)? Very very much doubt it
Sub woofer -
A 12" will not fit the stock location no. IMO its not worth replacing the sub without replacing the amp as well.
Head Unit output a special level (its between line level and phono) to the BOSE amp i.e. a sod to interface with but there are modules to do it
