loss of dash and clock /digital lights
help please.......as above ....check fuses in foot well and under bonnet but just cant find dash illumination fuse?
Someone else had a similar problem, a fuse labelled "Cigarette lighter" was blown and was causing the problem, I would check every fuse in every fuse box to start. If they are all ok then it could be the aircon control unit as it has an impact on some of the gauges when faulty/unplugged.
R
right ...dont know what i ve done but i ve got the dash lights working and the clock etc but it says it icy ? out.
god knows what ive done.
From what I've seen, the fuses don't really correlate to anything in particular - wouldn't fancy sorting out the wiring on the Zed!
I had some dash problems the other week after I was messing around, and in the end I did a manual ECU reset by unplugging the battery for around 10 minutes. Everything worked fine after that. Always worth a go. I'm assuming it isn't icy in Bournemouth? ;)
