relentless Posted December 23, 2008 Posted December 23, 2008 Is it wise to spray oil based paint over the water based paint on the Zed? (not entire car - just a few panels) Does it make a difference in terms getting a perfect match? cheers Mark Quote
breay Posted December 23, 2008 Posted December 23, 2008 As far as i know (but im no expert) its either water based paint or solvent thats used these days. Pretty much all body shops are meant to use water based paint as its better for the environment but the body shop i use still uses solvent as it dries quicker and is easier to use. Any way back to your question , as the paints use the same pigments they should be fine to use over each other although some would say that if the car was sprayed using water based paint then water based should be used to get a better colour match. Quote
Rob_Quads Posted December 23, 2008 Posted December 23, 2008 Most bodyshops still used solvent based paints. Can't remember which but its only the primer or colour thats water based i.e. I think they still mostly use a 2k primer Quote
H5 Posted December 27, 2008 Posted December 27, 2008 I think some of the better workshops do use water based now, the same as the manufacturers. The couple of places I use do use water based paint. IIRC, the water based are a bit harder to match. Quote
