JameZ Posted September 19 Posted September 19 Anyone fitted one of these and had problem with volume control? Just put one in and it blasts full volume on lowest settings. What's worse is that it came from the factory with an Avril Lavigne song in it 😠1 Quote
steadycurlew52 Posted October 4 Posted October 4 JameZ said: Anyone fitted one of these and had a problem with the volume control? I’ve just put one in and it’s basically blasting at full volume even on the lowest setting, so something definitely doesn’t seem right. To make it worse, it came from the factory with an Avril Lavigne song already loaded 😠Сasino 4u website gives me the same kind of reaction when a sound setting looks adjustable but behaves like it only has one level: technically the control is there, but it isn’t doing much. Has anyone run into this and found whether it’s a wiring issue, a bad unit or just how these are? Sounds like the amp gain is getting a full pre-out signal, not much range left for the head unit to work with. Factory Avril is a proper warning label though :D Quote
Rhett Calloway Posted October 26 Posted October 26 Updating the firmware or doing a factory reset could help, since that preloaded song points to leftover demo settings. Â Quote
